Smart Invoice Capture
A smart invoice profile uses machine learning to automatically capture the invoice date, invoice number, purchase order number, and total amount due, in typed or handwritten form, and can also determine the vendor of the invoice by comparing invoice data to a vendor lookup table.
Sort by:
Hello, Is it possible for the Smart Invoice capture engine to extract supported metadata from pages other than just page one? Thanks, Brian
