I have been trying to copy a folder structure from one location to another, without the files it contains - as seen in this question http://answers.laserfiche.com/questions/26826/Worfklow-Copying-Folder-Structure
I followed the advice given in the reply but when the workflow runs, the files are still being copied across (See attached image). I have encountered the same issue when exporting via Briefcase too. The selections I chose should only copy the folders,
but are copying the documents too.
The documentation for Workflow suggests that it should be possible to only copy folders (with subfolders), as seen here: Documentation. I selected the "Preserve Folder Structure" checkbox, and left all other checkboxes blank.
For reference I am using Worflow Designer 10.0.0.249, Laserfiche Server 10.1.0.151, and Laserfiche Client 10.1.0.151
