Failed to publish "does not contain a definition for 'TrusteeOptionsProperty' [0411-WF0]
asked on March 22, 2016 • Show version history
Hi,
I'm trying to publish a workflow and I keep getting this error (below).  We have reinstalled both the Workflow Server and the Laserfiche Server and every time I try and publish it fails.  It makes it through the validation, but when it actually tries to publish it gives the error.  Is there a way to fix this?
Note: this is a Laserfiche 10 VM environment, previously 9.2 (hence LF92Demo repository name).
replied on March 22, 2016
Hi Eric,
Putting an Invoke BP activity inside a For Each User loop has been confirmed as a bug. There is a simple workaround: instead of Invoke BP inside the For Each User loop, you can update a multi-value token with each Display Name. Then, in a For Each Value loop, you can Invoke BP. Here is an example workflow:
Let me know if this works for you!
Hi Alexander,
This did work for me.  I had to delete the original Invoke BP Activity and rebuild it, but once I did that I was able to publish.
Thanks!
