After migrating our Laserfiche, which started with version 6 and is now on 9.2, we have both older files and more recent files and I am wondering if maybe the handling of empty has changed over the years or versions of Laserfiche. If I search (advanced search) for Value = "" the results will include only recent documents that have the empty value, but not older ones. If I select all of the ones that SHOULD be returned and assign a value and then select them again and clear that value, then they will all be included in the results of a VALUE = "" search.
Has anyone encountered (resolved) this issue? I wonder if this type of thing also might occur if a new field is added to a template, since any existing documents on that template would never have had a value assigned?
