I'm working with a public entity that gives the public access to Oil and Gas records. Users frequently have the need to download documents from WebLink so they can be analyzed but WebLink always forces the download to be a .PDF. Well Logs are unique in that the page length can literally be a mile long for a single page. Pdf files have a limitation on what they are able to display. If you go to https://public.occ.ok.gov/OGCDWebLink/CustomSearch.aspx?SearchName=OilandGasWellLogsSearch&dbid=0&repo=OCC and perform a search by API Number = 3501926349 you should get 5 results. Try to download the one with DocID of 96356 and you will see the problem.
Does anyone know if there is a way to control the download file type? I want to set up a separate WebLink instance specifically for this type of document but have it set so that downloads will default to the native file format, especially when its native format is .tif
