Difference between Universal capture and Snapshot
asked on August 29, 2019
Hi LF Community,
Could someone clarify the difference between Universal capture and Snapshot ?
Best regards
replied on August 29, 2019
Universal Capture is a "Scan Source" in the Scanning applications (Scanning and Quick Fields) that processes images only.  Snapshot is a "Printer", so anything that you can print can be converted to an image.
You would use Snapshot to convert Word, Excel, or any other non-image documents into images in the repository.
You would use Scanning with Universal Capture to process image files into the repository.
3 0
