Quickfields QR Barcode - Problem Reading Barcode
asked on September 27, 2016
Recently we did an upgrade from Laserfiche Server 9.2 to 10.1. For various reasons QF wasn't included, so I am working on that transition now.
I have a fairly simple QF session that seperates documents and extracts information through a QR barcode on a cover page. The QF version 9.0.1.496 has no issues with this. The QF version 10.0.0.976 can't seem to process the QR barcodes at all. All I get is "The value for token %(Barcode 1) could not be found. [0222-BP0]".  This occurs for both QR barcode processes (one under "First Page Id" and the other under "Page Processing").
Is this a known issue with QF10 (and is there a hotfix)?
Both installations have the same features installed, except "QF Agent" and "Unidentified Classification".
replied on September 27, 2016
Please apply the Quick Fields 10 Update 1 patch found here: https://support.laserfiche.com/kb/1013788/
Please open a support case and attach the session and a sample image.
Just to confirm, does this have to go through our VAR? Or where would I submit the support case?
It has to go through your VAR. Unfortunately, we can't troubleshoot without the image, which I why it has to be a support case.
