Web Acces 10.1 opening entry when searching without click on it
asked on April 22, 2016
Hi everyone,
I am not sure if it is a problem or configuration, but I just updated Web Access to the version 10.1, and when I search a specific document through the quick search bar on the top of the screen, the search find the document and automatically open the document without waiting me to click in the document to open in another bar, as it was in the previous version. Is there anyone who knows what is happening or knows a way to change the configuration?
Thanks for the help.
Regards,
Vitor
replied on April 22, 2016
This is the default behavior. To disable it, set the [Search]OpenIfOneResult attribute to No. You can set it on the Everyone group to make it global for the repository.
Hi Robert,
Thank you for the answer. I added the attribute and now it is working fine as we wanted.
Thanks
Regards,
Vitor.
Was it the only result from your search?
Yes, it was.
I know that is the default behavior in the client, so they have changed that in Web Access to match.
Hi Blake,
I didn't know. Thanks for the update.
