Help with regular expression (admin console metadata field constraint)
asked on April 11, 2016
Hello,
I am trying to add a regular expression to one of our number metadata fields (using the constraint box within the admin console) and continue to get the error "The field constraint has a syntax error or is invalid". I have used the expression within workflow, quickfields, etc... and validated so not sure what is wrong besides constraints within the admin console are different from other areas of laserfiche. Below is the expression I am trying to use (validating numbers to have at least one decimal and correct comma separation if used). I have tried removing the starting/stopping elements and also adding forward slashes just to try to eliminate possible issues.
^(0|[1-9][0-9]{0,2}(?:(,[0-9]{3})*|[0-9]*))(\.[0-9]{2})$
Thanks for any help!
Kipp
replied on April 11, 2016
Hey Kip,
I see what you're doing and the issue is with the pipe for the OR statement. Looking to see if the Template Field Constraints offers another way to achieve this.
-Carl
Hi Kipp,
To do this, I believe you need to set the Field Type to Text.
The number fields use a different syntax for regular expressions and does not includes comma support.
Cheers,
Carl
Hi Kipp,
You can use the number field and have LF apply the commas automatically with a custom field type,  something like Custom [#,###,##0.0#].     User enter the number field without commas.   Then your RE becomes a simple check a checking for one decimal.
More details on custom number fields:
https://www.laserfiche.com/support/webhelp/Laserfiche/10/en-US/administration/#../Subsystems/LfAdmin/Content/Custom_Number_Field_Display.htm
Andrew
Thanks Carl/Andrew!
I was afraid the OR might be the problem, but wasn't sure. I might continue down this road but also might try the masking type solution Andrew mentioned. Need to talk with the users about a few of their requirements.
Thanks again!
Kipp
Well the custom format won't work because it helps the user but doesn't validate to make sure decimal points are present. I tried "text" but that didn't work either. My last try I dumbed down the expression to basically allow all number before a decimal and then 2 after and still no luck -- ^(\d{1,}\.\d{1,2})$
In the end I just need to make sure the field has one decimal point. I believe at this point I will put the validation within quick fields and workflow and solve in this manner.
Thanks again for the help
Kipp
Ah.
FYI Miruna's answer over here sort of walks around this OR issue and denotes the ()'s are only allowable in grouping constructs.
