Possible to reference workflow sql datasource from sdk script?
asked on April 7, 2016
Pretty much as the title says.
Is there a way to use a datasource defined in workflow (admin console -> External Objects -> Data Sources) inside a sdk script, instead of creating a whole new sql connection?
This would make it much easier to migrate workflows from a test/development environment to a production one.
Thanks.
replied on April 7, 2016
Not at this time.
replied on May 7, 2021
The question asked back in 2016, is there any update for 2021?
I have the similar situation that need access Data Source directly from SDK script. Right now I have to manually define data connection string which is already defined in WF.
Wondering anyone has a better solution?
