forms combo box multi value issue with PDF
asked on December 16, 2015
hi to all
in Forms i created Combo Box inside a Table and try to fill the PDF file with the selected value but i am not able to get multi value for more information i am attaching Forms , Workflow & PDF file.
https://www.dropbox.com/sh/zccbbq56aqc5gwb/AAB6Zzks1aap3WiIKbtK3Wlaa?dl=0
Thank You.
replied on December 21, 2015
Hi Mazahir,
The "Fill Out PDF" activity accepts only single-value tokens in each of its fields. You can "flatten" your multi-value token in the Token Editor by checking the "Apply Index" box, choosing the "All values separated by:", and picking a character to separate the values (screen shot below).
Let me know if this works for you!
replied on December 22, 2015 • Show version history
Actually, if you want to use a table, you should be configuring the activity on the Table tab shown in Alex's screenshots above, not in the Individual tab. The Table tab lets you define the column fields with pattern matching, so Workflow can set each value in a multi-value token in a separate row in the table.
You would have to modify the PDF so all the fields in the table are set up as form fields. Currently only the first row is fillable.
hello Alex
thanks for your kind support it is working fine.
wish you a Happy Holidays
