Using Workflow for Automated Filing - How To
asked on November 26, 2015
I have a WF that successfully files (and creates folders for, if needed) any documents with a Roll Number in the template field.  I would now like to take it a bit farther.
The new folders are created by WF in the folder called Roll Files using this routing info:  \- ADMINISTRATION\County Land Files\Roll Files\Roll #%(RetrieveFieldValues_Roll No_1#"D6"#).  But now there are so many of these folders, I have created subfolders (as shown below).
How can I get WF to check these subfolders for the indicated roll number before deciding to create a new file?
Thx, Connie Prendergast, Flagstaff County, AB, Canada
replied on November 28, 2015
Connie - If I can get you to change your folder numbering scheme a bit I can make this work with just two activities; an Assign Token Values activity and a Token Calculator activity.  Here is a screen shot of the workflow;
And here is a screen shot of the results;
The details for the Assign Token Values activity - Create a numeric token called 'SignificantDigits' based on the retrieved field value Roll#1;
Details of the Token Calculator - Create two calculated tokens, one called 'LowRange' and the other called 'HighRange'.  'LowRange' is 'SignificantDigits' * 10000, and HighRange is 'LowRange' + 9999;
The final routing info would be as follows;
\Roll Files\_Rolls %(TokenCalculator_LowRange#"D6"#) to %(TokenCalculator_HighRange#"D6"#)\Roll %([RetrieveFieldValues_Roll #1]#"D6"#)
Note: If you need to keep the subfolder numbering system that you described in your post then the only ways I could see to do that would require some type of iterative loop to determine the appropriate subfolder, or perhaps a script activity with some type of Select Case structure?
replied on December 2, 2015 • Show version history
Thanks, Cliff!  I'm working on this (was away for a few days).  I have set this up and end up with something not quite right.  Hopefully, a few more tweaks might make it right?
I'm close!  I took a test document and gave it the Roll # of 32400, then popped it into my target folder for this automated filing and Workflow created a file folder of:  Rolls 324000000 to 324009999.
It's creating the wrong Low Range and High Range.
How can I get the tokens to create the numbers to match 030000 to 039999 when it finds a roll number of 32400?
Thanks!  Connie
Can you add a Track Tokens activity at the end of the workflow to see what values are being assigned to the SignificantDigits token?  Here is a screen snip of my system when I use a Roll# of 32400;
I see the point of the \d\d now in the Significant Digits token.  :)  Correcting that.
HA HA HA HA YEAH!!!!  SUCCESS!  Thanks so much Cliff!!!!
Good!  Glad it is working for you!
Doing my happy dance!!  LF answers needs to have an emoticon with actions for the Happy Dance!  smiley
