Is there a way to ‘enable’ a business process based on the ‘TAG’ assigned to an entry? e.g- if certain tag is assigned to an entry, only then a business process can be 'viewed' or 'enabled' for that entry.
I know, there are certain options under Business Process Rule -> Requirements, that can be used to enable business process. But I don’t see Tags as one of the options.
Is there another way to do this?
