it is possible add code script in process model?
asked on August 4, 2015
I need to do some additional validations on the flow Process Model in FORMS, can I add SDK script code?
Like to SDK script tool in Workflow.
replied on August 4, 2015
You may be able to do that on the front-end with JavaScript. Can you give some examples?
You can call into Workflow with a service task, but you cannot add a script directly to the Forms Process Modeller.
What kinds of validations do you need to do?
I want to validate the name of attachments, if filenames are ok then send to Laserfiche otherwise not.
Thanks.
I want to get the filenames to extract some data.
The filename contains 3 data separated  by pipe carácter.
