Workflow not working when starting business process
asked on August 4, 2015
Hi all,
When a workflow is run through workflow designer using admin profile, the process flow is working fine.
But, when starting the business process from LF Client and connected as user profile, the workflow is not started.
Can you please advise what is causing this issue?
Thanks
Kind Regards,
Sheila
replied on August 4, 2015
Do you mean you can select the business process in the client and it won't run? In that case can you check if you can start any business processes at all? If not then you should check in the Workflow configuration manager that the Workflow Web Services are working correctly. If there is an error here then the workflow server and the client will have trouble communicating and BPs may not start.
