hardcode QF login info for LF Capture Engine
asked on August 3, 2015
Is there an option to hard code the login info so it does not ask for credentials each time?
replied on August 3, 2015
Please see this help page.
Optional: Select Require users to provide a login after opening this session: if you want users to enter their login information each time they connect to the repository using Laserfiche Capture Engine. When it is cleared, they will not need to log in each time. Their credentials will be remembered.
replied on August 4, 2015
Thank you!
