SQL Maintenance
asked on June 22, 2015
The Propval table in the reposirory database has around 290 million rows.
Can we use the SQL partitioning feature on this table because its causing delay in the backup and the index rebuild job?
replied on June 22, 2015
SQL partitioning is transparent to queries, so it should work. We have not specifically tested it at Laserfiche.
