posted on June 5, 2015
Hi,
I recently had a case, the Laserfiche server not started, to check the event viewer displayed the following message: "Could not load the module http", review the ports and port 80 was being occupied by Skype, the solution was to change port Laserfiche or Skype.
If you want to keep port 80 for Laserfiche you must change the port of Skype(https://hemantnemade.wordpress.com/2013/03/29/87/ ).
0
0
