Using SQL Express on a server that is already running SQL
asked on April 29, 2015
Is it possible to install Laserfiche with SQL Express on a server that is already running SQL?
Thanks!
APPROVED ANSWER
replied on April 29, 2015 • Show version history
Yes. You can install multiple SQL Express instances on a server (using different named instances) and even have SQL Express run on a server that also has full MSSQL. Note that when you install the optional SQL Express instance that ships with Laserfiche, it uses the instance name, "Laserfiche."
You may want to take into consideration the impact of resource usage when doing this though.
Thanks so much, Alex!
