We have a workflow process that invokes another workflow called Process Employee Files. The Process Employee Files workflow can run separately without being first invoked by the first workflow based on its own set of starting rules.
The only values the "Process Employee Files" workflow needs to work correctly are values from the metadata fields that are assigned to the documents. If I invoke the "Process Employee Files" workflow from another workflow, will the Retrieve Field Values activity work correctly or do I need to pass those values using input parameters?
