Help setting up exchange webservice
asked on December 31, 2014
I am looking to have workflow update calendars for exchange inboxes. The issue that I am running into is seen below:
The link that I am using in workflow to setup the exchange web service is an OWA exchange link.
replied on December 31, 2014
Tommy,
The standard OWA link is incorrect as it should be pointed at the web services URL. If EWS(Exchange Web Services) is not installed, you may need to install it on the server. For instance we use Office 365 and our URL is https://outlook.office365.com/ews/exchange.asmx
http://msdn.microsoft.com/en-us/library/office/dd877012%28v=exchg.150%29.aspx
replied on January 5, 2015
Thank you for the information.
replied on March 8, 2019 • Show version history
Hi John,
Are there any additional settings required for office365 ews to work with workflow?
