Is there a way to differentiate between an original document to a scan document in LF
asked on December 16, 2014
Hi All,
Is there a way that i differentiate an original scan document from other scan documents in laserfiche rio 9.3?
Is there any option that i need to select or enable?
thanks in advance for your reply
replied on December 17, 2014
If you are talking about scanned documents at the time they are scanned, you can simply give them a unique name together with a token to differentiate them.  Is this not possible or are you talking about a different process entirely and not about scanning.
The Laserfiche server doesn't really have any knowledge of the origin of any of the pages that end up in your repository.  Can you say more about what problem you are trying to solve?
replied on December 21, 2014
Hello Raymond and Brian,
Actually we want to find a way to differentiate between an original document and a copy document?
Is there a way to achieve this?
replied on December 29, 2014
Can you just compare creation dates?  The original will always be older.
