replied on December 8, 2014
Michael,
The easiest way is to make a pattern matching process that grabs just those three characters, and then use the new pattern matching token in the store path. If it is always three digits, you can get away with "\d{3}" as your pattern matching code after you remove the quotes.. Then set up your storage folders like normal, but at the end add the new Pattern Matching token you just made to the end. If using a field as an input, you will need to put the Pattern Matching part into the Post Processing section of Quickfields.
