Difference Between HTTP Web Request and Http Form Post?
asked on November 17, 2014
In the Workflow Toolbox there are 2 similar looking activities, Http Web Request and Http Form Post. Looking at their options, they look very similar with a couple differences. Can someone please explain to me what the differences between the two are?
replied on November 18, 2014
I don't find those descriptions from within workflow to be particularly helpful. The real answer is that they are both similar, and that the Web Request is the more general option of the two. By default, the Web Request activity is set up to be a HTTP GET request, but it is capable of making POST, PUT, or DELETE requests as well. The Form Post activity is set up by default to be a POST request, with the option of changing it to a PUT request. I'll leave it up to you to research the differences between the various HTTP request types.
The Web Request activity is more flexible and customizable. If you wanted, you could set up a web request to POST in the same way as the Form Post. However, you are also free to structure your POST or PUT requests in any way you like, as it provides an editor and a blank textbox. The Form activity is set up to be easily configurable to insert a series of (name, value) pairs as a form submission only.
Bottom Line: It's probably more convenient to use the Form Post tool if you're just making a simple form submission, rather than writing your own POST request in a Web Request activity. If you are only trying to GET information from a resource, then the web request is your only option.
HTTP Form Post
Sends a multipart/form-data POST request to a Web service and returns the result in tokens.
HTTP Web Request
This activity sends a request to a Web service and returns the result in tokens.
0 1
Khaleel, I was able to see those as the descriptions for the activities in Workflow. I was looking for more insight on them as the descriptions are not very helpful when wanting to know details.
3 0
