I have a client using Separator Sheets to identify for Quick Fields Agent the need for all documents following the separator sheet to be inside the same folder. Within those documents, will be other unique separator sheets that will be used to identify the individual documents, of varying types. I have configured all this to work in Quick Fields, and it works nicely.
My issue is with making sure that workflow, which needs to act on the folders after its finished being processed by QF by moving the folder, does not move the folder before it's ready. Does anyone know any ideas on how to do this? Some of those folder separators indicate certain subfolders to use for the last part of the folder structure, so this may cause the folders/documents not to all be stored in the repository in the order they were originally captured, but in the alphabetical order they now are in with the folder structure, or is that to change when moving to storing the documents immediately?
