replied on October 23, 2014
Sorry for the delay, I have been asked to create a work order system. The first of 4 forms is the end user request which collects their Employee number or Student Number, their location, position, and all the assets assigned to them are loaded into various fields, they then select an asset, problem type and enter a description after which they can submit the form. I need a second form to be accessible at the approval stage with all this data read only and a changeable status, action taken and route to fields for the site tech to use. If the equipment needs to go to our repair team, a third form needs to be processed their with all the previous data as read only and similar fields added for status, labor, parts, time, comments, and inventory flags. They would like all of this to happen inside a single forms workflow before the final submit of request completed at which it would be saved to the repository and a PDF filled and filed to an IT folder with short cuts in the employee/student file and the technicians involved files.
Is this possible?
