auto populate email for saved form to continue later?
asked on September 30, 2014
Is it possible to have the field auto populate with the submitter's email? since this field only shows up when the check box is checked. Thanks!
replied on September 30, 2014
in previous versions, you can add a hidden field and use it to have a default value of the users email address. Set that field to have the class, EmailField
From there, you can use the following to copy the value and store it into the field for the email:
   var userEmail = $('.EmailField input').val();
   $('input.saveresumeinfo:nth-child(2)').val( userEmail ); // Set the email address
replied on September 30, 2014 • Show version history
What version of Forms are you using? In Forms 9.2 there is now a Save Draft button that will show for logged in users and will save it to a Draft area of the system for them.
thanks for the suggestions guys.
