Hi,
The following are some requirement of a tender:
- Ajax Based: The application must be Ajax based; it needs to have reduced number of hits to the web server and fewer page refreshes. It should provide faster response time and enhance user's experience.
- The application should include a built in help management module, which provides the ability to create online help specified to the context of each application, and according to the cultural behavior of the working department.
Is Laserfiche compatible with the above? how can we reply on these requirements?
