We are looking to do Batch Importing of Documents.
My thought was to reduce Import Time we could have the users drag and drop documents and then use Workflow and DCC to OCR the documents.
I have tested drag and drop with a batch of TIFF images and DCC works fine to OCR those documents.
However I have done the same test with Non-Searachable PDF's and the Workflow Runs but the PDF's are not OCR'd even though the Workflow is successful and the DCC process states a Successful Task.
Is it possible to use DCC OCR to OCR Non-Searchable PDF's. I even tried first Generating the Images for the PDF without Searchable Text. Still DCC OCR does not OCR the PDF's. Does DCC work with PDF's or only image files?
Alternately can you think of another way to batch process PDF's in a Workflow to generate Image Files and OCR them?
