Installing the OCR OmniPage 18.5 Engine with unattended client installation
asked on June 13, 2014
 Hi,
Because the OmniPage 18.5 engine is installed separately from the client installation now, is there a new install level in order to install that component with the unattended install?
Thanks,
Brian
replied on June 16, 2014
http://www.laserfiche.com/support/webhelp/Laserfiche/9.1/en-US/AdminGuide/LFAdmin.htm#Installation/Install_Level.htm
Basically, it's 50, as it effectively was before. That just calls in the external msi instead of doing it inside the Client msi.
replied on April 4, 2016 • Show version history
Justin,  I'm looking at doing the same unattended install for the OCR Omnipage 18.5 and I had another related question.  If I choose an install level 300, that should execute all the install levels below 300 down to, and including, level 1.  Therefore I should not have to separately script to run the install level 50 for the OCR Omnipage.  Is that correct?
Please note that I am doing this for a Laserfiche 10 install.
Please advise regarding correct selection of install levels to accomplish this.  Thank you.
Yes, Installlevel include everything lower than the current value.
Thanks, Justin. I appreciate your help with this.
