«Entry Changed» Starting Rules vs Changes to Document Links
asked on May 30, 2014
«Entry Changed» starting rules appear not to be evaluated by Workflow Subscriber when links from/to documents are added or removed.
Can someone confirm this statement?
Any pointer to an exhaustive list of events that trigger Workflow Subscriber to run against «Entry Changed» starting rules?
replied on May 30, 2014
Linking documents does not generate notification events in Workflow. If you add a condition for "entry changes" to your rule, you will get a list of all entry changes that will generate notifications.
Should I understand that no notifications are generated when templates are unassigned?
Any chance of a feature request for notifications when links from/to documents are added or removed?
Thanks Miruna
