Document links in Word 2007 will not open to WebAccess document using IE 11
asked on May 22, 2014 • Show version history
I have a hyperlink in Word 2007 that contains a URL link to a document in Laserfiche Webaccess.  The link has worked fine until I upgraded IE to IE 11.  Now, when I click on the link, it just takes me to the sign on page for Webaccess.  Before it would take me directly to the document.
I am currently on Laserfiche 8.1 and Windows 7 64bit.
APPROVED ANSWER
replied on May 22, 2014
If you sign in once and then try the link again does it work now?
Also, please note https://support.laserfiche.com/KB/1012418 (supported configurations). Web Access did not officially support IE 11 until version 9.0, given that it only came out last year.
replied on May 23, 2014
Hi Justin,
No, it will work fine if I paste the link directly into the browser address bar.  However it will not work if the link is in word and you do a ctl click to launch the link.  It worked fine a week ago before I upgraded to IE 9 to IE 11.  IE 11 is the only piece in the puzzle that has changed.
