Is there a way to limit search results in workflow to only return a distinct value, or loop through a For Each Entry of an activity for distinct values, or only retrieve distinct values?
asked on April 17, 2014
I'm creating this workflow to send each responsible employee a list of the accounts they are responsible for resolving that have been outstanding more than 30 days.  The email looks great because after retrieving the User ID from the first search, it is used to loop through results of a second search that is specific to their User ID; however, the same email is being sent to the same user for each entry in the search result containing their User ID.  If there are 12 entries in the results of the first search containing their user ID, they will receive the same email 12 times.  I don't want to obtain the User IDs from an Active Directory group because they're not configured yet, and some of the entries are for terminated employees.  Is there a way to do one of the following?:
Limit the results of the first search to only show the first entry for each user
Only loop through the search results once for each user
Only retrieve distinct field values from the search
Thank you!
replied on April 17, 2014 • Show version history
It sounds like that will work.  After the second Assign Token Values activity, do I need another For Each Entry activity or For Each Value activity?
Yes. Then you'll want to foreach over the new list of values.
Your first foreach will only collect the initial set of values, and the second one will pretty much be the same as what you've got in your screenshot.
You could have the Determine Users loop add each user ID to a multi-value token. Then after you have the list of user ID's (with possible duplicates) you can assign that list to another token and apply a Remove Duplicates Token Function as part of the assignment.
replied on April 18, 2014
That was the trick.  You are awesome!!! Thanks for your help Devin!  Attached is the finished product for anyone's future refrence.
This might be too late, but if you use business processes, the Workflow Server can take care of collecting that data for you and sending out notifications.
replied on April 18, 2014 • Show version history
We're not using Business Processes yet, but hopefully soon. smiley
