Looking at best practices for doing backups of LF repos. the document mentions putting volume into "read-only" state, i tried it by just using the Admin console set a volume to read only state.
It worked great for "documents/files" however the gotcha was I could remove/rename/add new folders in the repository. So, the "read-only" state is not a true read only state, is this a known bug in LF 9.0 and has this been addressed in 9.1 version ?
I do not know how the back-end code works but I can see a problem when doing backups assuming no change to the Repository is taking place but in fact that is not true, will it put my backups in corrupt state if someone renames a folder while backup is being performed on a "read-only" volume ?
