8.1.2 Installation Guide
asked on February 19, 2014 • Show version history
Specifically looking for the install command line options.  For whatever reason I'm unable to find that guide online.
Was that the same as currently available?
\\path\setup.exe -iacceptlicenseagreement -noui (or -silent) ?
or was it setup.exe /s /v/qn ?
thanks
replied on February 19, 2014
We didn't start having online help until 8.2, I believe, so that's why you can't find it. I don't think it was the same, but there should be a copy of the documentation on the installation media or once installed. It would be lfadmin.chm underneath Program Files (x86)\Common Files\Laserfiche\Document.
