unattended installation of Laserfiche Products
asked on February 19, 2014
One of our client are looking for the method of Unattended Installation for all of the Laserfiche Products.
We have managed to provide them the CMD string for LF Server, LF Admin Console and LF Client Installations, so all fine.
Can you please confirm if a n Unattended installation for LF Workflow, LF Web Access an LF Import Agent is also possible?
Miruna has already confirmed in one of my previous post, that unattended installation for Quickfields is not possible.
replied on February 19, 2014
Pretty much all of our installation packages these days use the same frontend setup.exe bootstrapper project and therefore also use most of the same commands, even if they aren't specifically documented. First off, you can run setup.exe -? on them to get some of the commands specific to that package. Also, a good tip is to run a logged setup installation (Setup.exe -log "C:\logFolder") and you can actually see what paramaters setup is passing along to your msi's.
Basically all the installation packages that use this particular setup.exe have the same command paramaters as what is documented for Server/Client. INSTALLDIR, ACTIVATIONKEY, INSTALLLEVEL to determine which components to install (if you just want everything you can usually just put 1000 here) or LICENSEPATH, SVCACCOUNTNAME/SVCACCOUNTPASSWORD for services, etc... If you have a command line that works for Server or Client, there's a pretty good chance it'll work just like that for the others, you just might need to experiment a bit (and logging a representative setup run should help with that if something turns out to be non-obvious).
Now, this only applies to newer packages, like IA 8.1.3, WA 9.0, etc... Basically, if the setup.exe looks and acts the same as the Client/Server's, it will use the same parameters.
3 0
replied on February 20, 2014
Justin,
Thanks a lot for the details.
I was building command line to run Quickfields and Workflow but I have a confusion.
Here is my command line for LF Server:
"D:\Install\setup.exe" -silent -log "C:\Logs\ServerInstall" INSTALLLEVEL=150 LICENSEPATH="E:\lf.licx"
LFSSVCACCOUNTNAME="Domain\SRVUser" LFSSVCACCOUNTPASSWORD="Password" LFFTSSVCACCOUNTNAME="Domain\SRVUser" LFFTSSVCACCOUNTPASSWORD="Password"
For Workflow, I changed it like:
"D:\Install\setup.exe" -silent -log "C:\Logs\WFInstall" INSTALLLEVEL=1000
LFWFSSVCACCOUNTNAME="Domain\SRVUser"
LFWFSSVCACCOUNTPASSWORD="Password"
LFWFSubscriberSVCACCOUNTNAME="Domain\SRVUser"
LFWFSubscriberSVCACCOUNTPASSWORD="Password"
Key words for workflow 9.1 and workflow subscriber service in the command above are suspicious? specially the subscriber one.
I first assumed it's the service name but apparently it's not because the service name for LF Server is LFS (keyword for cmd line is: LFSSVCACCOUNTNAME)  and the service name for LF Full-Text Indexing is LfFTSrv (keyword for cmd line is: LFFTSSVCACCOUNTNAME).
My guess is that the keyword I would be passing for LF Workflow Server is: LFWFSSVCACCOUNTNAME and for subsciber: LFWFSubscriberSVCACCOUNTNAME    ???
Above keyword for subscriber service looks wrong to me.
Any suggestions please?
Thanks
The Workflow installation is not set up to configure the service user for the either one of the Workflow services. Both services need to be configured beyond just specifying the service login, so their accounts are specified through the Workflow Configuration Manager.
0 1
In general (independent of Miruna's specific comment above), you only need to use the keywords if you want to send commands specifically to different modules. So if you wanted to use a certain value in all cases, you could just use SVCACCOUNTNAME. You can do that in the Server installation as well. You only need to specify both LFSSVCACCOUNTNAME and LFFTSSVCACCOUNTNAME if you want them to be different for each product.
3 0
replied on February 25, 2014 • Show version history
Thanks a lot Justin.
Very useful smiley
replied on July 29, 2014
LaserFiche owes money to Uzair Sheikh....
There is NO documentation on unattended installations of anything except the Rio Client.
BIG thanks to you Uzair.
1 1
I don't believe there is an unattended installation for any of the above mentioned as there is no documentation on it. I'm not sure why you would want an unattended installation for Web Access though as there is nothing on the client side to install, it is a server installation.
Hi Blake,
The purpose is to have command lines ready and saved for any future installations.
This way we can run it easily, if a new Administrations joins the company, without interacting with the installation wizard.
Regards,
Uzair
Thanks Justin.
I have fully functional command lines for the installation of LF Server, LF Admin Console + Client and LF Client only.
I will edit the same commands and give it a try for rest of the products.
Thanks for your help.
