Laserfiche system was supports a Hardware Security Module (HSM) or not
asked on January 1, 2014
Hello,
We have one customer and he wants to know if Laserfiche system was supports a Hardware Security Module (HSM) or not ?
Thanks
replied on January 2, 2014
Laserfiche does not support any HSM modules at this time, as we have not run into any use cases that would warrant it. However, there is nothing that prevents organizations from implementing an HSM solution at the operating system level. For example, when users turn on their computer in the morning, they can use an HSM module to log into the system, and then log into Laserfiche using their Windows or Laserfiche credentials. Depending on your customer's use case, this may be an acceptable alternative.
