Since Forms does not provide an entry ID when using the save to repository task, isn't there a way to use just the path when we want to link someone to something saved in the repository as part of the process?
I looked through the documentation and it seems everything goes by Entry ID. That means we need a WF just to lookup the entry ID based on a Path.
Am I missing something here or can you use the path in the URL rather than entry ID.
