Web Client-Log In Page Modifications
asked on February 1, 2024
Hello,
We have a customer who would like to know if it is possible to do the following:
  1. Remove the User/Pass and Windows Authentication options as they use SAML
  2. Customize the login page to show their Municipality Branding
I know there is a config setting to remove the other login options, but can't remember this process specifically.
Appreciate the feedback,
Jeff Curtis
replied on February 1, 2024
Jeff, removing the username and password fields and Windows Authentication option are built into the LFDSSTS configuration page. The screenshot you posted is actually of the LFDSSTS and not the Web Client login page. When you open the LFDSSTS configuration page you should see these two options:
3 0
replied on February 6, 2024
Thanks Blake
Jeff
