Is there any way to hide Common and Records Management Columns on Weblink Column Picker?
asked on September 7, 2023
Hi Everyone,
We would like to hide the Common and Records Management columns on weblink so our clients can see only the relative fields to them. They shouldn't be able to see who creates the file or cutoff date etc. Is there anyway to do that?
Thank you!
Onur
replied on October 27, 2023
So I found out that there is a way to hide records management search and I did it but nothing happened. Not much of a coder and not sure where to add the code on WebLinkStyles.css. I tried to add at the end.
select[name="TheSearchForm:_ctl2"] {
display:none;
