Hi,
My organization prioritizes version control for our files, but a lot of versions can be created when a file is interacted with by many users, regardless of how impactful a particular instance of editing can be.
I would like to request that you be able to designate a version as major or minor, but also that you be able to set separate periods for each type to be retained natively in the system, so that major versions can be retained for the lifetime of the document, but minor versions are kept for a shorter period of time, so as to avoid cluttering up version listings and bloating system storage. Being able to designate that period at the folder level would be even better, because then you could tailor that obsolescence period based on the particular type of document and its corresponding edit cycle lengths - if this is too complex though, being able to do it at a high level would be immensely helpful.
Thanks!
