asked on July 30, 2023
Hello Team,
I have template with Multi-value group fields as per attached file.
I have requirement to update metadata of specific group using the Laserfiche sdk but I am not able to found any specific code. Yes for individual fields I have ready code and its running fine but having problem with multi-value fields.
As per screen you , see that we have group of 5 with many field values inside it and I need to udpate specific value under the specific group.
Thanks,
Pratik
0
0
