How to read json envelope from cloud workflow?
asked on June 10, 2023 • Show version history
In the activities of the workflow I did not find a way to read a json structure.
This activity exists in the on-premises workflow but not in the cloud.
THANKS
replied on June 13, 2023
You could use Pattern Matching to create tokens by pulling the Values from between the identifiers ie: <fieldname>(.*)</fieldname>
very interesting idea, thank you
replied on June 12, 2023
Parsing JSON is available as part of the configuration of the Web Request rule.
Thanks Miruna.
It does indeed make sense to put it here.
In the On Premise version, this activity allows you to read a json even without making an hhtp web request. In fact I wanted to use it to read the result of the execution of a script.
