We are preparing to upgrade from version 10 to 11. Our largest repository holds around 8 TB, all in a single logical volume. The maximum physical volume size is set to 20GB, so we have several hundred of them.
Will the large logical volume or the large number of physical volumes cause me problems in the future? Should I look to change the volume structure of the repository, and if so, where can I find instructions on how to do that?
I would welcome references to documentation on these topics. Thank you.
