Posted to Laserfiche Cloud
Error: The archive entry was compressed using an unsupported compression method.
asked on February 16, 2023
I get this message when I click on Request Signature with DocuSign:
Any idea?
replied on February 16, 2023
The message is pretty clearly about a compressed archive being deemed invalid, but it's hard to say which of Laserfiche and DocuSign created the archive, and which thinks it's invalid. There should be more details in the Event Viewer on the web client server.
replied on February 17, 2023 • Show version history
I just realized you posted this to Laserfiche Cloud. I did find that error message in our logs, and opened ticket #414346 to investigate.
I don't see any other occurrences of this error, which is often an indication that it's related to the data involved. Is it possible there's a problem with one of the documents you are sending to DocuSign?
replied on February 21, 2023
To sum up where we are, I think the root cause here is one of:
  1. Problem with a document in your repository. Maybe something was imported as a zip but with the wrong extension?
  2. User error - is someone sending DocuSign data that they can't handle?
  3. A bug in our software, but which only manifests in a particular flow.
In any case, we would need you to open a support case to move forward with this.
