Forms 11- Side by Side layout not working
asked on December 21, 2022
Hello,
We updated a customer to Forms 11 Update 2 yesterday and they have an issue with a Form they had built in 10.4.5, that they converted to the new Forms Designer, where their Layout of "Side by Side" is showing as stacked in the Form.
They ran a repair of the Forms instance and the same issue still occurs.
Appreciate the feedback,
Jeff Curtis
APPROVED ANSWER
replied on December 29, 2022
A support case had been opened and then closed. The explanation provided by Jeff was that the issue was due to a low display resolution setting on the user's screen and increasing the resolution allowed the form to display properly.
replied on December 22, 2022
I am able to test in Forms version 10.4.4 and 11 Update 3 and it works as expected. I would open a support case for them.
Hi Jeff,
Can you open a support case and provide the exported process? Thanks.
