Is there any way to have Workflow Monitor Searches give me more results than the standard 500 limit?
asked on October 10, 2022
When i do searches in Workflow Monitor - I need more results that the 500 limit. Mainly I need this for statistics to know how many workflows have run in the last hour for example.
Laserfiche Cloud has Limits like 25000 workflows per hour, the Monitor Search tool seems to give you the ability to search with this criteria, however the Results stop at 500 so if 20000 workflows ran in the last hour you would have no way of knowing based on this tool. Am i missing something here, are there some settings i can play with or should i be looking elsewhere for this type of information?
It would be great to have a way to get these types of speeds and feeds, since the system is throttled and requires some finesse on the part of the Workflow designer to control the events that cause the system to exceed the System Limits and then for workflows to be terminated unexpectedly due to one of the limits being exceeded.
Thanks for your kind response in advance.
Milton.
replied on October 11, 2022
The statistics are available from Manage. As you select a workflow, the right pane will display various information about it, including how many instances have run recently.
Thanks Miruna, I will check that out.
