Need to create concatenated list of values from first column of table and insert into multi-line text box
asked on August 18, 2022
I have a table with multiple customer records.  I'd like to be able to loop through the table and extract each customer's name into a comma separated list to place into a multi-line text box.  I'm assuming I'll need to use javascript for this, so if someone can help get me going with an example I would appreciate it very much.  Here's a snapshot of the fields in question.
The goal is to populate q140 with a comma separated list of customer names from the table class coverletterCustomers and update that list every time a new customer (class "internalCustomerSelect") is added.
Thanks in advance for any assistance.
replied on August 18, 2022 • Show version history
The column variable will return a comma-separated list by default if you don't use an index, so all you really need to do is add a calculation and set it equal the that variable.
You can make the field read-only and it will still work.
The calculation would get more complicated if you wanted to ignore empty rows or add a space after the comma or something.
For example,
To add a space after each item, instead of just returning the column variable directly, you could use the JOIN function.
=JOIN(", ",Table.Column)
Thanks Jason!  I always learn something new from you and Matthew.
