asked on July 12, 2022
I have noticed an issue where you have to enter the value twice when changing the path where the scanned document is going to be saved and also when changing the metadata from a drop-down list.
Example:
  • I have an unidentified document so I right-click on it and choose Assign Document and give it the appropriate document class.
  • I rename the document without any problem
  • I click into the path where the document will be saved and change the path by adding the employee number at the end, for example I would change \HR Scanning\Layoff-Transfer\%(EmpID) to \HR Scanning\Layoff-Transfer\1234.
  • I press the Enter key and the value changes BACK to \HR Scanning\Layoff-Transfer\%(EmpID).
  • I edit the path again and hit enter; this time it keeps the new path
Something similar happens when I change the metadata.  The first time I go into the metadata drop down and choose a doc type such as "Layoff-Transfer".  When I tab out of the field, it switches to the first value in the drop-down list, which is 401k Enrollment.  If I go back into the drop-down and choose Layoff-Transfer, this time it keeps the value.
Possible bug?
