Good day,
We have a laserfiche form that inside of it contains other 5 forms. We need to add a new field on the form. But once I add the new fields it gave me a variable, but I want to use the same variable for the other forms. Because if I add a new field for all forms is going to provide me with different variables. This would cause a problem for the workflow/data base because this will require us to add more fields on the DB. I see other fields on the current form that all forms have the same variable, but not on this new one.
I do see the variable on the "variables fields" but when trying to drag and drop.. it disappears
